2007 Chevy Aveo ACCERATION PROBLEMS
2007 CHEVROLET AVEO
16,000 MILES • 4 CYL • FWD • AUTOMATIC
DENNISAVEO
  • 5 POSTS
i have a 2007 chevy aveo , i changed the spark plugs and the spark plug wires .
but when i started it it did not sound right , i drove it down the street and the rpm's were high but the car was moving real slow .
so i rechecked the plugs and the plug wires and i found that at the end of the spark plug wires did not reach the tip of the spark plug .
i put back the old set of spark plug wires but I'm still having the same problem , high rpm's slow movement .
any clue to how i can resolve this issue ?
Aug 19, 2010 at 4:02 PM
BDOGG0070
  • 42 POSTS
Sounds like a trans issue. Could be a sensor in the trans or the trans itself but if yo have a warrenty with the dealership yo bought it from I would let them fix it because if you do anything like that to it, that would void the warrenty
Aug 19, 2010 at 4:06 PM
DENNISAVEO
  • 5 POSTS
Why would the trans be affected from changing the spark plugs and spark plug wires ?
i don't understand why replacing the plugs and wires would mess with the trans
Aug 19, 2010 at 4:20 PM
BDOGG0070
  • 42 POSTS
I know it does not make much sense but i have seen stranger things. It also does not make much sense for the engine to rev high and car not accelerate much either. If it was a sensor you may have inadvertainly disconnected something while changing the plugs and wires. That tends to happen a lot more than you would think.
Aug 19, 2010 at 5:38 PM
DENNISAVEO
  • 5 POSTS
thank you so much , i'll get back under it right now and look everything over thank you for the input :)
god bless you always
I'll let you know if that's what had happened
again god bless
Aug 19, 2010 at 5:44 PM
DENNISAVEO
  • 5 POSTS
WOW , THE PROBLEM WAS THERE WASN'T ANY TRANSMISSION FLUID .
TO BE HONEST I WAS STILL STUMPED FOR ABOUT 45MIN UNTIL THIS MAN WAS WALKING BY AND HE SAW THAT I WAS FLUSTERED WITH THE CAR .
SO HE ASKED WHAT PROBLEMS I WAS HAVING , SO I EXPLAINED IT TO HIM AND HE LOOKED OVER AT ALL I HAD DONE TO FIND EVERYTHING WAS DONE CORRECTLY .
THEN OUT OF NOWHERE HE SAID HE KNOWS WHAT IT IS .
HE WENT RIGHT FOR THE TRANSMISSION DIPSTICK AND LOW AN BEHOLD IT WAS BONE DRY .
I COULDN'T BELEAVE WHY I DIDN'T EVEN BOTHER TO CHECK IT BEFORE LOL .
BUT I STILL WANT TO SAY THANK YOU bdoggOO7O FOR TAKING THE TIME TO HELP ME WHEN I WAS IN SO BADLY IN-NEED FOR SOME ADVICE .
THANK YOU AND GOD BLESS YOU AND YOUR FAMILY
Aug 20, 2010 at 2:36 PM
BDOGG0070
  • 42 POSTS
Thank you for letting me know and if I had it at my shop I would have probably thought of that as well. But I didn't expect that in a 2007 model car. Your next step should be to find out where it is losing the trans fluid and fixing the leak. More than likely it will be a cv axle seal. Please feel free to leave some feed back.
Aug 20, 2010 at 2:48 PM
DENNISAVEO
  • 5 POSTS
MY OLDER BROTHER SAYS I SHOULD TAKE IT TO A TRANSMISSION SHOP AND GET IT LOOKED AT.
AND WHATEVER IT IS THAT THE SHOP FINDS WRONG WITH IT , TO BUY THE PARTS AND HE WILL HELP ME FIX THE PROBLEM BECAUSE HE KNOWS I CANT AFFORD THE LABOR COST GETTING IT DONE IN A SHOP.
WHEN I GET THE CHANCE TO GET IT LOOKED AT WHICH WILL NOT BE PROBABLY FOR ANOTHER COUPLE OF DAYS .
BUT AS SOON AS I FIND OUT WHAT IT IS THAT'S WRONG WITH THE TRANSMISSION I PROMISE TO LET YOU KNOW WHAT THEY SAY IS THE PROBLEM.
THANKS AGAIN FOR YOUR TIME
GOD BLESS ALWAYS
Aug 20, 2010 at 3:24 PM
BDOGG0070
  • 42 POSTS
make sure you keep an eye on the trans fluid level untill you can get it looked at.
Aug 20, 2010 at 3:39 PM
