2005 Chevy Aveo brake lights staying on
2005 CHEVROLET AVEO
61,000 MILES • 4 CYL • FWD • AUTOMATIC
DRIFDAR
The brake lights on my 2005 Chevy aveo started staying on the other day. I haven't had any accidents, or any other incidents that could have damaged the car. I did notice that the brake pedal is about 1/4 to 1/2 of an inch away from keepin the plunger on the switch compressed. Is the switch bad, or do I need to adjust the brake pedal, and how do I do that????
Apr 21, 2009 at 11:16 AM
The plunger should be depressed by the brake pedal arm this will open the brake circuit and when brake is applied the plunger should extend closing the brake circuit turning on the brake lights. Try adjusting the brake switch so that the brake arm is compressing the plunger to turn off the light.
Apr 21, 2009 at 6:21 PM
