2005 Chevy Aveo Aveo makes sputtering noises
2005 CHEVROLET AVEO
66,000 MILES • 4 CYL • FWD • AUTOMATIC
CASN79
My Chevy Aveo is making a loud sputtering noise and yesterday after I had driven it for a 100 miles the oil light started to flicker in rhythm with the sputtering. A week ago I scraped a driveway that we think pinched the line that runs from the transmission, though i don't know what it is called, it is just a line that hangs low, but appears to have wires in it. My boyfriend says it has a tube in it too and it transfers transmission fluid. I noticed a large puddle of what we are pretty sure is transmission fluid under the car a day after i scraped it. And that same line seems to be where the leak was coming from. Today when i drove it the oil light did not come on until I came to a stop at a light and only while i was stopped, it went away when i pushed on the gas. Also when i press the gas pedal in slightly the sputtering gets worse and then when i push the pedal even further it is not as bad. I had heard a faint sputter when i pushed the gas pedal slightly over the last year, but no one else could hear it. Yesterday it also paused before actually shifting into gear and then it jerked forward (that happened twice) Hasn't done it today. I lifted the hood today and the sputtering was definitely coming from inside the engine. I will be taking it to a shop, but i'd like to get an idea of what i am in for and what to call around for on quotes.
Apr 12, 2010 at 10:52 AM
MHPAUTOS
  • 31,937 POSTS
Hi here,
Thank you for the donation,
You will have to first get the leak check and identified, if you have damaged the trans cooler line you will be running low on oil and this can cause serious damage to the transmission, this is important to check first, the other issue may only be tune related, get the trans check and repaired before it fails and costs $$$$$ to fix.
Mark (mhpautos)
Apr 14, 2010 at 4:16 PM
