Hey gmandr,
Thank you for your question.
There are a couple of options for early and later production vehicles.
Below i have attached instructions to remove the interior trim (Door panel upper extension)
I have then attached the door panel instructions starting with early all the way through to the later production models.
Also for some useful general information regarding this repair be sure to check out the 2CarPros repair guide at:
https://www.2carpros.com/articles/door-panel-removal
Either way once the screws are removed the door panel should pull up to release from the door.
Hope this helps, let us know if you have any further questions. Check out the diagrams (Below). Regards, Joe
Feb 19, 2021 at 1:05 PM
(Merged)
