How do I remove the headlight housing to replace the bulbs?
Nov 9, 2009 at 12:03 PM
CERTIFIED EXPERT
Most you can access the bulb socket from under the hood. If that is not possible, look along the rad support behind the assembly. You will see black slides that will slide up so you can remove the assembly.
Hello, my name is Robert and I own a 2005 Chevy Avalanche 1500 without the body cladding/plastic pieces. I want to change my fatory headlights out for a set of Euro projector headlights with the halo. The problem is I can only find them for the 2005 Chevy Silverado 1500. My question to you is are they the same headlights? Will they fit on my truck?
May 20, 2020 at 1:31 PM
(Merged)
CERTIFIED EXPERT
Hi:
I believe the mounting brackets are different. Please confirm that with the light manufacturer.
Sorry, but I don't know the manufacturer or have cross reference information for you.
(Merged)
SROMERO1
MEMBER
1 POST
Electrical problem
2004 Chevy Avalanche
how do I change the low beam headlight bulb. I found the where to change the parking lights, but can't get to the headlights.
(Merged)
MOBILEOILANDMORE
MEMBER
On the driverside you must remove the battery to access the bulb. It is a tight fit so you've really got to work at it.
