Heater blower does not work, appears that fuse is good.
Dec 24, 2009 at 11:51 AM
HMAC300
CERTIFIED EXPERT
disconnect the wire to blower. put a testlight connected to the wire and turn the blower switch on if it lights, then it is probably the blower motor bad. If not check your blower motorresistor for the different speeds and relay if you have one.
