2004 Chevy Avalanche the transmission feels heavy
2004 CHEVROLET AVALANCHE
95,000 MILES • V8 • 2WD • AUTOMATIC
JENSENMARK
as if some trailer stretched
does not change the third change of speed
Sep 20, 2010 at 1:02 PM
HMAC300
  • 48,601 POSTS
it's best to have a trans pro check this as it may be ann elctrical problem inside the trans. It could also be that a clutch pack is going bad or a seal has worn out. make sure your fluid is full. The trans pro can scan the trans to see if there are any problems with shift valves, etc. YOu could have two clutches applied at the same time that aren't supposed to be.
Sep 24, 2010 at 12:52 PM
