2003 Chevy Avalanche guages
2003 CHEVROLET AVALANCHE
88,000 MILES • V8 • 2WD • AUTOMATIC
GRISELTYE
my speedometer goes back and forth from correct to off by 20 or 30 mph, my rpm gauge is stuck all the way up to 6, and my gas gauge always says empty. HELP!!!
Mar 22, 2009 at 4:26 PM
Hi:
This could be a BCM, ground, or insturmentation problem. With the newer GM's, all gauges can be tested with a scanner to see if they work. I would start with that. If they work (with scanner), then I would have the BCM tested.
Mar 23, 2009 at 1:42 PM
