2002 Chevy Avalanche Rough startup in cold weather
2002 CHEVROLET AVALANCHE
113,000 MILES • V8 • 4WD • AUTOMATIC
COWBOYBOB
My 2002 Avalanche with 113,000 miles on it has a problem with a very rough start up during cold weather (below 40 degrees). It bucks and jumps and surges and misses for about 5-7 minutes. Once it is warmed up it seems to run fine. The engine light does not come on. For these vehicles and engines I have read that it could be a manifold leak, a faulty gas pump, an air throttle valve problem or using 10% ethanol fuel. I have yet to take it to a repair shop. I am curious as to what the real problem might be since this problem seems to be fairly common.
Jan 20, 2010 at 2:46 PM
Hi cowboybob, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve, test the following coolant temperature, throttle position, and manifold absolute pressure sensors-to include the PCV and EGR valves
Jan 20, 2010 at 4:05 PM
