Hello, I have question. I hope you can answer. I have a 1999 chevy Astro 4.3L. 95,675 miles on it, auto trans, 2 wheel drive.
I scanned the vehicle and It is showing P0304 and P0300. Misfire at #4 cyl p0304, and Random misfire P0300.
So far I have changed the coil , distibutor, cap, rotor , wires, plugs (AC delco), Control Module and map sensor. I checked fuel pressure (61 PSI), checked oil pressure (71 psi @3000RPM) And it is still Mifiring same codes popping up.
I checked the # 4 plug dry after a run and wet after another run. hmm...I don't get it..Oh I aslo checked main voltage wires at coil (near 14 volts) and near 14 volts at dist. relucter. Please help..
Sep 19, 2007 at 8:32 PM
