loss of power steering and power brakes
CHEVROLET ASTRO
FRANKIESADIE
my 2000 chevy astro van with vortec v6 got stuck. upon unsticking after a lot of effort my power steering and power brakes went out at the same time. do you have any ideas
Jul 13, 2007 at 8:52 AM
BOOTDOG
  • 665 POSTS
check to see if you lost the fan belt, check the p/s fluid level, if those are ok then the p/s pump went out. the pump runs fluid through the hydro booster which gives you power brakes.
Jul 14, 2007 at 4:51 PM
FRANKIESADIE
[quote:9f68d2f9a0="bootdog"]check to see if you lost the fan belt, check the p/s fluid level, if those are ok then the p/s pump went out. the pump runs fluid through the hydro booster which gives you power brakes.[/quote:9f68d2f9a0]
the shaft for the pulley was broken. do you need to bleed the system or just let it run for a while and turn the steering wheel back and forth and make sure not to run low on fluid
thanks
Jul 28, 2007 at 11:41 AM
BOOTDOG
  • 665 POSTS
just turn the wheel back and forth till all the air is forced out the top of the pump.
Jul 29, 2007 at 6:34 AM
