front end 1994 astro cl
1994 CHEVROLET ASTRO
SHAWN0314
  • 6 POSTS
the frontend is making a howling noise, i got the van from my ex wife, her b/f is a semi mechanic, he thinks the frontend is going out, i think it's tires MAYBE upper or lower tierod , also when i step on the brake it pulls to the right, they just got done putting new front brakes on it . back to tihe front end , it is leaking some fluid i haven't looked to see if it was gear oil or something else. kinda help me here, if it is frontend then i'm going to the junkyard to get it , shawn
by the way, the van has 275,000 miles on it
Jun 14, 2007 at 5:35 PM
BOOTDOG
  • 665 POSTS
ok this is a shot in the dark, by the way you're describing a howling noise and a fluid leak, i'm guessing a power steering fluid leak. possible pump, line or steering box. with the vehicle pulling while braking, possible broken motor mount. give me more details if possible.
Jun 14, 2007 at 11:42 PM
SHAWN0314
  • 6 POSTS
my buddy got me thinkin, since they put new brakes on the front, it could be a wheel bearing (s) shawn
Jun 16, 2007 at 12:28 PM
