Door Locks
CHEVROLET ASTRO
MIKE1WADE
Door locks and remote entry worked fine prior to my trying to install door locks to Bulldog remote starter system using their wiring diagrams and instructions, on 99 chevy astro with 88,000 miles It didn't work, removed the newly installed wiring. Smelled like electrical burning. Now, have No remote key entry at all. Locks work intermitting from switch on the drivers door. However, Drivers doesn't lock or unlock with power. Ran 12volts directly from the battery, to drivers door actuator ,worked both ways. Voltage at actuator plugin was 11.24 volts at best on one side , the rest of the readings were under.30 volts either direction,,Also the dome light doesn't come on when the door is open, I think I need a new light switch, because the override doesn't work at all. Please tell me where the lock relay is located, so I can change it If a signal is sent from the drivers lock switch to the other locks and they work a couple of times, I don't think it is that switch, Bulldog has been little and no help on this issue. Can you help???
Nov 23, 2007 at 8:35 PM
FISHERMAN
  • 937 POSTS
[quote:a8a2265f3d="mike1wade"]Door locks and remote entry worked fine prior to my trying to install door locks to Bulldog remote starter system using their wiring diagrams and instructions, on 99 chevy astro with 88,000 miles It didn't work, removed the newly installed wiring. Smelled like electrical burning. Now, have No remote key entry at all. Locks work intermitting from switch on the drivers door. However, Drivers doesn't lock or unlock with power. Ran 12volts directly from the battery, to drivers door actuator ,worked both ways. Voltage at actuator plugin was 11.24 volts at best on one side , the rest of the readings were under.30 volts either direction,,Also the dome light doesn't come on when the door is open, I think I need a new light switch, because the override doesn't work at all. Please tell me where the lock relay is located, so I can change it If a signal is sent from the drivers lock switch to the other locks and they work a couple of times, I don't think it is that switch, Bulldog has been little and no help on this issue. Can you help???[/quote:a8a2265f3d]
Hello Mike!!
No Problem!
We have the power door lock circuit schematic, that can guide you to check the wiring and find the problem I`m going to send it to your e-mail (to big to post it and has to be reduced)
Also The location of the door lock relay its:
Behind right kick panel
thanks a Lot for your donation!
PM your e-mail adress...
Nov 23, 2007 at 9:10 PM
MIKE1WADE
[quote:c1597eed97="mike1wade"]Door locks and remote entry worked fine prior to my trying to install door locks to Bulldog remote starter system using their wiring diagrams and instructions, on 99 chevy astro with 88,000 miles It didn't work, removed the newly installed wiring. Smelled like electrical burning. Now, have No remote key entry at all. Locks work intermitting from switch on the drivers door. However, Drivers doesn't lock or unlock with power. Ran 12volts directly from the battery, to drivers door actuator ,worked both ways. Voltage at actuator plugin was 11.24 volts at best on one side , the rest of the readings were under.30 volts either direction,,Also the dome light doesn't come on when the door is open, I think I need a new light switch, because the override doesn't work at all. Please tell me where the lock relay is located, so I can change it If a signal is sent from the drivers lock switch to the other locks and they work a couple of times, I don't think it is that switch, Bulldog has been little and no help on this issue. Can you help???[/quote:c1597eed97] Update,,ran 1 wire from the relay to the actuator, ran one wire from the lock control module to the other side of actuator as per schematics still no power lock to driver door actuator!!!!!
Dec 5, 2007 at 8:48 PM
MIKE1WADE
Update,,,,ran one wire from lock relay to actuator, ran another wire from door lock control module to the other side of actuator, still no driver door power lock!!!!
Dec 5, 2007 at 8:52 PM
