1) Engine starts intermiittently, will crank over but no start. I checked for spark and there is spark, the plug is also wet. I can hear the fuel pump prime up. Engine sputters at the first key turn. There is pressure at the fuel test point but not sure if it is within 51-59 psi.
2) When engine does start, it idles nicely but when I step on the gas the engine boggs out to almost a stall until I take my foot of the pedal, returns to idle.
I changed the starter modual, MAP sensor, new fuel filter and new pump. I also adjusted the Throttle position sensor which made an improvment but still missing power when stepping on gas once i got going.
Jeff, Calgary, AB
Jeff, Calgary, AB
May 29, 2007 at 1:37 PM
