2003 Chevy Astro multiple issues
2003 CHEVROLET ASTRO
119,000 MILES • 6 CYL • AWD • AUTOMATIC
TLBADER
I multiple problems with my Astro. The brake lights (both light) come on periodically but doesn't affect the brakes. The mechanic figures ita sensor but doesn't know which one. The remote locks just started to work periodically, you think the vehicle is locked but it isn't. I tried to lock the vehicle sitting in it and the lights come on and goes off the locks start to engage put quits before they lock. Then starting the vehicle and putting in drive the transmission doesn't shift properly, it revys up then shifts as you drive. It only does this right after starting the unit. If you pull to a stop sign and take off it shifts properly.
Sep 12, 2010 at 6:20 PM
WILLIAM_STELTER
  • 24 POSTS
Well for the brake lights it is probally just a sensor. You cant tell unless you replace them both. Should run about $10.00- $20.00 a piece. They are under your dash . look right where you brake petal is. follow the bar up there is to sensors that when the petal is pushed they push out. easy to replace....just unscrew and put on new ones. The rest I dont know Hope this helps :)
Sep 24, 2010 at 6:48 AM
WILLIAM_STELTER
  • 24 POSTS
https://www.2carpros.com/forum/automotive_pictures/575692_brake_1.jpg
Sep 24, 2010 at 6:50 AM
