2003 Chevy Astro coolant
2003 CHEVROLET ASTRO
450,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBOCKLET
I want to replace radiater coolant I need to know how to flush out old fluid,& how much fliud it takes to refill
May 21, 2009 at 8:52 AM
Drain the old coolant from the petcockl at the bottom of the radiator. Based on what brand of radiator flush you purchase will determine the process. The manufacturer will have the directions on the container. Also, if you only flush the radiator, figure around 1.5 gal 50/50 mix of coolant / water. Make sure to use the proper type of coolant. DO NOT MIX FACTORY DEXCOOL WITH ANY OTHER TYPE OF COOLANT.
Jun 1, 2009 at 9:30 AM
