Hello, How do I check the problem codes for the engine performance? I know that there is a pin connector under the dash on the driver side, you used to be able to short a couple of pins out to get a flashing read out on the dash.
updated 6/1/09
thank you for the info, I did purchase an OBD11 scanner from JC whitney to view the codes. also I wanted to change the dex-cool coolant out of my 02 ASTRO, do I need a coolant evacuator to remove all of the coolant from the engine block? Is there just one coolant plug on the engine block of a 4.3 Lt. engine or two plugs? What happens if the coolant is to rich, more than 70% dex-cool?
Thanks
updated 6/1/09
Thanks
May 26, 2009 at 8:57 AM
