Engine Performance problem
2000 Chevy Astro 6 cyl All Wheel Drive Automatic
I've checked codes and other sources and believe teh MAP sensor is the source of rough running, stumbling and misfires. It it likely a fix can be effected by repairing the connections, including the vacuum lines, or does the sensor itself go bad as a rule?
Any other suggestions, tips or hints?
Sep 11, 2009 at 6:52 PM
