my 2000 chevy astro has serious hesitation problems when accelerating. I'ts had a full tune-up with no improvemt. The scanner shows misfire on cylinder #4 @ idle and misfire on all cylinders @ load. I've replaced the coil, fuel pump, spider web injector system and have had a compression test with the results of 180 lbs. of pressure per cylinder, the MAF sensor is working fine. What am I missing? HELP PLEASE. Thanks, Terri
Nov 24, 2009 at 12:54 AM
