Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Astro
Steering
Symptoms
Grind
2000 Chevy Astro grinding from steering
2000 CHEVROLET ASTRO
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUZZY1050
MEMBER
1 POST
FOLLOW
When it's cold, below 45 degrees my steering makes a grinding noise when I make a full turn of the wheel.
Nov 24, 2008 at 8:38 AM
CERTIFIED EXPERT
Hi:
Does the sound come from the steering column? If so, the bearing inside the column is most likely the problem.
Nov 27, 2008 at 10:27 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Grinding noise is probably the power steering pump unless noise is located in steering column as Jacobandnickolas pointed out.
Nov 27, 2008 at 10:50 PM
