1999 Chevy Astro miss fires
1999 CHEVROLET ASTRO
152,000 MILES • 6 CYL • 2WD • AUTOMATIC
KINGSMAN47
when you first start it up it miss fires or just misses after the motor is hot it run good. i had bad gas in it now it's good gas with a v-checker reader on it it just saids miss fire
Oct 26, 2009 at 10:07 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Do you have the actual code it should be something like P0300 or P0301 - 306. If not your local parts store can pull the codes. Post them here.
Also when was your last tune-up?
Oct 26, 2009 at 10:30 AM
KINGSMAN47
I get bought it it's a nice van so I don't know when it was last tuned-up. The code was P0300
Oct 26, 2009 at 1:51 PM
OBXAUTOMEDIC
  • 3,711 POSTS
OK,
Here is the code def....
P0300 Random/Multiple Cylinder Misfire Detected
So, first thing I would do is pull a plug or 2 and see what they look like. If they look worn then I would do a tune-up and see if that corrects the problem. 8 out of 10 time is does.
If not other possibilities are....
Vacuum Leaks
Low Cylinder Compression
Weak Fuel Pump and/or Pressure Regulator
For more check out the link below...
https://www.2carpros.com/first_things/why_does_my_engine_run_rough.htm
Oct 27, 2009 at 10:06 AM
KINGSMAN47
Thanks for your help I had a vacuum hose that was broken in two
Oct 27, 2009 at 1:57 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, great did that fix the Misfire? If so congrats on the fix.
If not let me know so we can do more diagnosis.
Oct 29, 2009 at 9:35 PM
