My 1997 Astro has 76000 miles. Until recently, usually under load, the A/C would sometimes not blow out the dash vents, only the defrost and under-dash. Taken off load, the problem would go away. Recently, the problem does not correct and the a/c now does not blow out the dash vents at all. A check under the hood revealed a small (1/16 I.D.) vacuum line is broken. This line connects to a "T" right next to the a/c dryer. The line runs back across the top of the block, toward the driver's side, but I cannot see where that end terminates. Where does the line go and how can I access it to replace it, presuming this is the cause of my a/c problem. thanks
Sep 5, 2019 at 3:21 PM
(Merged)
