1998 Chevy Astro Radio Removal
1998 CHEVROLET ASTRO
ROOKIE21
Electrical problem
1998 Chevy Astro 4 cyl Two Wheel Drive Automatic
I would like to upgrade my factory installed radio and i can't seem to pull it out of the dash despite removing all of the screws....is the radio attached to something inside the dash that i can't see??? do i have to remove the entire dash to change the radio??? it's my first time doing this....any suggestions??? thanks..
May 21, 2008 at 1:14 AM
TECHMAN1
  • 82 POSTS
[quote:8467367fe6="rookie21"]Electrical problem
I would like to upgrade my factory installed radio and i can't seem to pull it out of the dash despite removing all of the screws....is the radio attached to something inside the dash that i can't see??? do i have to remove the entire dash to change the radio??? it's my first time doing this....any suggestions??? thanks..[/quote:8467367fe6]
Get the glovebox/drink holder unbolted with the 2 - 13 millimeter nuts on the floor and the 2 - torx 30 on the sides and rip the glovebox out of it's plastic clip retainers (not to far because you have to unplug the cigarette lighter and accessory power feed plug.)
You do not have to remove the whole dash, but you may have to take out a couple screws at the driver's door end of the dash surround. Just flex it out from plastic keepers and only about half way across to the center. This does not disturb the instrument cluste on the main dash console for speedometer, etc.
Rip the surround from around the radio area from it's plastic keepers.
By the way, lots of Astros have stereo wires for the rear but no speakers. The rear speaker plug you want is under the floormat where the speedometer cable comes through the floor. There will be a 10 wire plug. The 4 wires you want will all be in a row. LR+ is yellow, Left common is brown, RR+ is dark blue, Right common is light blue (maybe with a dark blue stripe).
Good Luck
Ken
May 23, 2008 at 10:12 PM
