1998 Chevy Astro FUEL DELIVERY
1998 CHEVROLET ASTRO
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAROPPI
Here is my problem: At regular fuel pressure of 58 psi the van starts up easily. after running for a short period of time the fuel pressure drops under 50 psi and stalls. Right before the van stalls,as the pressure drops, the fuel pump makes a lower pitch sound. With engine off fuel pressure doesn't drop it stays at either 58 or little above 40. When it stays at 40 psi it is imposibble to start the engine. After few atempts to start the van the sound of the fuel pump goes back to hi pitch and pressure goes back to 58 and the engine starts right up. I replaced the fuel filter and recently I also changed the fuel pump. Thanks for any suggestion . John
Mar 12, 2009 at 9:49 AM
JDL
  • 16,098 POSTS
Hello, before you start it, cycle the key a few times, on and off, see if the pressure comes up? You might check actual voltage at the pump, ground also. Key on or engine cranking is battery voltage at the pump. Engine running, alternator voltage.
Mar 12, 2009 at 10:33 AM
