1998 Chevy Astro front axle noise and vibration
1998 CHEVROLET ASTRO
167,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE CANNON
My 98 astro awd has an intermittent shudder like driving over rumble strips at a turnpike exit alert and a whine or growl like mud grips on pavement(pass. side). when van shudders,I tap on brake lightly and shudder stops. I already paid to have the c-v joint,hub,bearing where drive shaft goes into front pumpkin replaced.I found axle rod had slipped out of placein pumpkin and into c-v and damaged splines.he dressed splines and reversed shaft.paid "mechanic" over 1000.00 for several wrong guesses at the problem.I can't send a donation right now,I will definitely be able to do so as soon as I fix the van and my money isn't the retirement fund for "mr wrong wrench".Can you please give me a clue as to where to start,My son has mechanic training but no drive train exp.He will be doing the work.PLEASE HELP!
Feb 27, 2008 at 10:14 PM
KFUSMC
It sounds like one of two things. And I know the Mr Wrong Wrench probably said that a couple of times. But it seems that the tire on the passenger side might have thrown a belt requiring replacement. The other suggestion would be to check the brake rotor for warping. If the tire is fairly old, I would have a tire shop see if they could diagnose a bad tire. If you drive a lot in stop and go traffic, then the rotor could be warped.
Kyle
Feb 27, 2008 at 10:29 PM
