[quote:39e6ddb457="obxautomedic"]Hello,
Here is what you will need to do....
Disconnect the coil from power
Pull the #1 plug out you will then need to get the Piston to Top Dead Center(TDC) on the Compression Stroke.
Once there pull cap off distributor and make sure the rotor is pointing at the #1 plug tower on the distributor. If it is then is should be in right.
If you are have running problems double check you firing order.
.[/quote:39e6ddb457]
How do i get to TDC on the compression stroke? Is there a visible mark? If it's not pointing to the #1 plug do I pull the distributor and reseat it?
Thanks for all your help!!
Oct 6, 2009 at 1:18 PM
