1998 Chevy Astro chevrolet astro
1998 CHEVROLET ASTRO
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
LUIS ELEUTERIO
1 have 98 chevrolet everthig was fine.
one day i was check bad fuses with a test lighter,
when i wanted to star the engine nathings happen.
I check the battery starter, alternator, any bad fuses, ign ect.
everthing is ok.
please i need you help.,thank you. luis
Dec 18, 2007 at 7:30 AM
DENNYP
  • 1,824 POSTS
First, you need to make sure you have 12 volts going to the starter solenoid control wire when you turn the ignition key to crank position. It should be a small purple wire. If you don't have voltage, you need to test the starter relay. If that's ok,suspect a faulty ignition switch.
Dec 21, 2007 at 7:46 PM
