1997 Chevy Astro Vibration starting at 40 mi/hr.
1997 CHEVROLET ASTRO
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
SGREEN7
I'm trying to troubleshoot a vibration that has recently started with my 97 Astro. The vibration starts at around 40 mph. I've checked tire pressure, lug nuts, and tires for bulges and all are fine. I recall having a classic Volvo some years ago, that developed a similar condition, which turned out to be the driveline support bearing. I was able to fix that. I'm wondering if this should be the next place I look to correct the problem or if there could be other conditions going on? If there is a strong possiblility that this is the problem, can the work be done by a home mechanic?
Thanks alot,
sgreen7
Jan 3, 2010 at 7:15 PM
BMRFIXIT
  • 19,053 POSTS
tires outof balance
Should have the tires checked 1st and also do a high speed balance on them
Jan 4, 2010 at 6:20 AM
