1997 Chevy Astro replacing power steering pump
1997 CHEVROLET ASTRO
135,000 MILES • 6 CYL • AWD • AUTOMATIC
DALERIEDEL
I am not able to remove the bolts on the back of the power steering pump. i am trying to replace the pump due to broken shaft in old pump. is there away tio remove theese bolts
Jul 13, 2010 at 11:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
will have to remove hood latch and upper radiator fan shroud. then use pulley remover to remove pulley from pump shaft. then remove a/c compressor to access the PS pump bolts.
Jul 14, 2010 at 1:19 AM
MG4187
Don't need to take off a/c compressor to access bolts. Manual does not indicate that it needs removal.
Apr 18, 2026 at 9:38 AM
