1995 Chevy Astro remove seat belt drivers side?
1995 CHEVROLET ASTRO
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
G7HEJ
hi how do i remove seatbelt and casing from drivers side, is it the t50 torx bolt i can see through plastic trime, or are there something else holding it on. can seat belt mech. be serviced as it is not catching on every snatch?? failed MOT
regards graham
Mar 9, 2009 at 10:24 AM
JAMES W.
  • 2,394 POSTS
The torx head bolt is the only thing holding the unit to the frame, but they can be a "bugger" to lossen. GM uses blue thread locker on these bolts and it makes it tough to make that first round. As far as it missing a few clicks. Usually a good spray lube will get them working without removal. Hope this helps.
Mar 9, 2009 at 12:59 PM
