1995 Chevy Astro PLUG ISGETTING WET WITH GAS
1995 CHEVROLET ASTRO
ANTSDETAILMAN
Engine Performance problem
1995 Chevy Astro 6 cyl Two Wheel Drive Automatic 1OO.00 miles
HOW DO I GET THIS TOSTOP HAPENING OR WHAT CAN I DO.
Jan 29, 2009 at 6:04 AM
BMRFIXIT
  • 19,053 POSTS
Check it for tune up
check coil
check wires
do a compression test
check for codes
Jan 29, 2009 at 6:09 AM
JDL
  • 16,098 POSTS
I'd disable the fuel system, then check for spark at the plugs. If the plugs are gas soaked, you may not be able to use them, use a known good plug or spark tester.
Do you have the cmfi fuel system? Maybe a faulty poppet or injector.
I just wanted to add, that cmfi is an assembly, I don't believe you can replace individual parts. I'd check everything else first.
Jan 29, 2009 at 6:16 AM
