1995 Chevy Astro Fuel Questions
1995 CHEVROLET ASTRO
154,000 MILES • 6 CYL • AWD • AUTOMATIC
IZZYMT
I am currently driving a 1995 Chevy Astro Van AWD with a 4.5 liter fuel injected V6. The biggest problem I have is the smell of leaking gasoline when I am driving. The second problem I have is the whining that occurs when I accelerate. When stopped, the vehicle shudders when the gas pedal is pushed down. Anyone that could provide an answer to these problems would be helpful!
Nov 30, 2009 at 5:31 PM
JCARLTON58
  • 12 POSTS
try fuel pressure guage turn key on it will go up to about 60 psi and should not go down if does look at fuel lines 4 a leak and if not might be injector under intake and i think you have a 4.3 w motor
Nov 30, 2009 at 6:57 PM
IZZYMT
[quote:ae47623f81="jcarlton58"]try fuel pressure guage turn key on it will go up to about 60 psi and should not go down if does look at fuel lines 4 a leak and if not might be injector under intake and i think you have a 4.3 w motor[/quote:ae47623f81]
That's what I meant. I hit the wrong number
Nov 30, 2009 at 6:59 PM
