My engine light has come on and it states that the IAC valve is malfunctioning, i got code 35. i changed the iac valve today with a new duralast valve but my van is still running rough at idle and it seems lke its accelerating on its own. What can be the problem? I still get code 35. When i installed the IAC valve i thought it would all fix but nothing changed, rough idle still there, did i install it wrong was i supposed to do something to the IACbefore installing? Or maybe the MAP sensor is wrong or EGR valve is wrong which is causing IAC to malfunction!! Please help! i dont know what may be the problem!
Jan 2, 2008 at 3:27 PM
