1995 Chevy Astro
1995 CHEVROLET ASTRO
SCE160
I have a 1995 Chevy Astro, It started hesitating couple weeks ago, so I did a tune up kit, plugs, wires, dist cap ,ect. Now its worse, it seems like its cutting out when I give it any gas, but it idles great and runs fine in reverse, no hesitation, but as soon as i put it in drive it won't run right. I changes the erg, and check the fuel preasure, all seems fine, no error codes, but the a couple erg 32 codes, nothing since I replaced all these parts. It has 115,000 miles on it and the fuel pump has been replaced, any ideas ?
Aug 10, 2007 at 1:56 PM
MERLIN2021
  • 17,250 POSTS
Sounds like a vacuum leak, if as you say the fuel pressure is good! get some spray gumout and do some spraying! when the idle changes, you found a leak!
Aug 14, 2007 at 3:46 PM
