1994 Chevy Astro no lights, no horn,no fuel pump, but turns
1994 CHEVROLET ASTRO
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
TED.GILLETTE
Sirs,
I have a 94 astro that died. No, lights, no fuel pump, no horn, but it does turn over. Fuses at fuse panel are good, Fusable links behind battery pass continuity check. Left side of fuse panel first column dead. Hot wired ecmb fuse and lights worked but still no fuel pump. What do I do ?
May 22, 2009 at 9:42 PM
BMRFIXIT
  • 19,053 POSTS
Its a wiring for sure
check the starter relay for fusible links
need to find the reason behind it burning off
check fuel pump wiring and wiring harness around exhaust manifold
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 23, 2009 at 5:53 AM
