Hello, if your datalink connector has 12 cavaties like the picture, you can access trouble codes, if there are any. Use a jumper wire between the A & B terminals, turn the key to on, no crank, the check engine lite starts flashing, you count the flashes to get the codes.
Also, I'm not sure of your vehicle vin? Vin W is the spider fuel system, that system is noted for problems. If it is a misfire problem, I can't tell if it is spark or fuel,maybe something else?
May 1, 2009 at 6:20 PM
