1993 Chevy Astro No power
1993 CHEVROLET ASTRO
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOMWILLY
  • 7 POSTS
I have 93 astro van after checking fuses under dash I replaced the fuel pump because it was not running with key on. It still did not run then I tested old pump on battery and it worked. so I figured good fuses good pump must be power problem , I hot wired pump then the van started and ran with out hot wire to pump. I figured it had to be computer and replaced it. It did not help. I started looking more and checked 5 fuse links behind battery they are all good. I figured what the heck and tried to read computer. and notice they are no check engine light burning. I am now stumped. please help
Apr 13, 2009 at 2:07 PM
MERLIN2021
  • 17,250 POSTS
Pump should run for 2-3 seconds with key in on posistion, and continiously in crank and run, if not check the fuel pump relay, the ignition swtch, and the connector at the pump. Check the IGN fue(s0 under the hood, and some GM's put the circuit on the cigar fuse under the hood.
Apr 13, 2009 at 2:59 PM
TOMWILLY
  • 7 POSTS
you did not adress problem with no power to check engine light. when jumping a hot wire to fuel pump it seems to back feed to ecm then the van starts and runs with jumper to fuel pump removed. then will not start again untill hot to fuel pump is reconnected with hot jumper then it will start and run with again.
Apr 13, 2009 at 3:53 PM
MERLIN2021
  • 17,250 POSTS
I did address it! Check the fuses I mentioned above! One of them feeds the ecm and the power to the DLC circuit.
Apr 13, 2009 at 4:05 PM
TOMWILLY
  • 7 POSTS
checked the 5 molded fuse links is this what you are calling a cigar fuse!
Apr 13, 2009 at 4:15 PM
MERLIN2021
  • 17,250 POSTS
Do you have the owners manual? Get back to me right away as I am going to log out shortly...
Apr 13, 2009 at 4:39 PM
TOMWILLY
  • 7 POSTS
no I only have a chilton manual it it dost show anything
Apr 13, 2009 at 4:44 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Astroa_1.jpg
FUSE & CIRCUIT PANEL IDENTIFICATION 1 - 10 Amp Instrument Panel Lights 2 - 30 Amp Circuit Breaker Power Accessories 3 - 30 Amp Horn/Dome Lights, Digital Clock, Cigarette Lighter, Radio Memory, Glove Box Light 4 - 20 Amp Ignition/Gauges, Cruise Control, Headlight Switch, Ashtray Light, Brake Switch, Audio Alarm (1993) 5 - 25 Amp Auxiliary Heater (If Equipped) 6 - 20 Amp Stoplights, Hazard Flasher, Digital Instrument Cluster 7 - 20 Amp Tail & Parking Lights, Headlight Switch 8 - 20 Amp Turn/Back-Up Lights 9 - 20 Amp Heater/A/C 10 - 10 Amp Radio 11 - 10 Amp ECM B 12 - 10 Amp ECM I 13 - 30 Amp Circuit Breaker Power Windows 14 - 25 Amp Windshield Wiper 15 - 10 Amp Daytime Running Lights (Canada Only) 16 - 15 Amp ABS Brake, Speedometer (1993) 17 - 15 Amp Foglights Page 1 of 1 FUSES & CIRCUIT BREAKERS -1993 Chevrolet Astro 4/13/2009 Check #'s 4, 11, 12, ok? No fuse links are just that, fuse links, forget the cigar fuse for now!
TOMWILLY
  • 7 POSTS
yes they were all ok, plus checked power both sides ok
Apr 13, 2009 at 4:48 PM
MERLIN2021
  • 17,250 POSTS
To help diagnose much further I need the engine size, and do you live in the rustbelt? If yes go ahead and check the fusible links too, and look at the ground at the thermostat housing if it has one there.The other possibility is the ignition switch could bad.
Apr 13, 2009 at 4:53 PM
TOMWILLY
  • 7 POSTS
as in orignal mesage I have allready checked fuses and fuse links, yes i did check grounds to body and engine they are ok as orgirnally stated also the engine is a 4.3 v 6 the only one put in a astrovan
Apr 13, 2009 at 4:57 PM
MERLIN2021
  • 17,250 POSTS
SERVICE ENGINE SOON (CHECK ENGINE) If a problem occurs in engine control system, ECM grounds light. Light should come on when ignition is turned on, then go out when engine starts if no problems exist in engine control system. Page 1 of 1 INSTRUMENT PANEL -1993 Chevrolet Astro 4/14/2009 If it does not come on check the connection at the ECM, may be loose, or bent / misaligned pins, bad ground, or bad ECM.
https://www.2carpros.com/forum/automotive_pictures/62217_Pina_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pinb_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pinc_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pind_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pind_2.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pine_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pinf_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_ping_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pini_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_pinj_1.jpg
Check the power and grounds for the PCM at shown connectors and wire colors, also check power to fuel pump relay.
Apr 14, 2009 at 1:39 PM
