1993 Chevy Astro head Gasket repair
1993 CHEVROLET ASTRO
APAPPAGIAN
Engine problem
1993 Chevy Astro 6 cyl All Wheel Drive Automatic 187K miles
I have had the head gasket repair jusrt done. on a otherwise smooth running 1993 Astro..then a friend said- since it is high miles - about 187 K I shouldn't have had it done because i will invariably have a lot of problems now. My question is - what ishould the warranty be? and second. is it true that now I should expect problems. THis has been a great vano, ther than problems with EGR valve and water pump it has been trouble free. thank you
Jan 31, 2008 at 10:46 PM
BLACKOP555
  • 10,386 POSTS
the only way it will run rough with the headgasket changed is if the person working on it doesnt know what they were doing and did a piss poor job.
there is no way fixing a problem gonna make it run worse, if you kept it the way it was youd cause more harm then good.
Mar 21, 2008 at 1:05 PM
