1992 Chevy Astro NO injector pluse when very cold
1992 CHEVROLET ASTRO
404,000 MILES • 6 CYL • 2WD • AUTOMATIC
GARYHUFF
Have fuel pressure, Spark, 2 second prime/ keyon
12 volts to both injectors and pink V+ to computer.
Computer grounds good to chassis.
Motor will crank and sometimes pulse injectors after 30 0r 40 seconds, sometimes not. Condition gets more prevalent a temps near O degrees. I understand that pulse width is made up of several summed values but I do not know where or what generates the initial base pulse. The ECM tested good out of car..could not test PCM. No hard codes set and no access to P codes.
Runs good once started . TPS voltage normal w/ 1.4vdc closed 4.5vdc WOT.
Jan 26, 2009 at 1:12 PM
KHLOW2008
  • 41,814 POSTS
Hi GaryHuff,
Thank you for the donation.
Here is a description of the fuel system and based on the open loop functions, you should be checking
1. Engine Coolant Temperature.
2. Mass Air Flow sensor.
3. Crank or vcam sensor. If you have sparks, then these two are less likely to be the cause.
FUEL CONTROL
The ECM, using input signals, determines adjustments to the air/fuel mixture to provide the optimum ratio for proper combustion under all operating conditions. Fuel control systems can operate in the "open loop" or "closed loop" mode.
Open Loop
When engine is cold and engine speed is greater than 400 RPM, ECM operates in open loop mode. In open loop, ECM calculates air/fuel ratio based upon coolant temperature and MAP or MAF sensor readings. Engine remains in open loop operation until O2 sensor reaches operating temperature, coolant temperature reaches preset temperature and a specific period of time has elapsed after engine starts.
Closed Loop
When O2 sensor reaches operating temperature, coolant temperature reaches a preset temperature and a specific period of time has passed since engine start-up, ECM operates in closed loop. In closed loop, ECM controls air/fuel ratio based upon O2 sensor signals (in addition to other input parameters) to maintain as close to a 14.7:1 air/fuel ratio as possible. If O2 sensor cools off (due to excessive idling) or a fault occurs in the O2 sensor circuit, vehicle once again enters open loop mode.
On 4.3L engines, oxygen sensor is equipped with an internal heating element. This element enables system to reach "closed loop" sooner and maintain closed loop even during periods of extended idle.
There are 3 different types of injection system and since you mentioned 2 injectors, it should be this system.
Throttle Body Injection
Injectors are located in throttle body unit. All models except 2.5L use 220 Series dual injector throttle body. 2.5L models use 700 Series single injector throttle body. Battery voltage is supplied to injector when ignition is on. ECM energizes injector solenoid by providing a ground path through its internal circuitry. By regulating injector ground circuit, ECM controls injector "on" time (pulse width) to provide proper amount of fuel to engine.
Pressure regulator maintains pressure to injector at 9-13 psi (.6-.9 kg/cm 2 ). Excess fuel passes through pressure regulator and returns to fuel tank.
In the "run" mode, ECM uses tach (RPM) signal to determine when to pulse injector. Fuel injectors are pulsed once for each engine revolution; each spray provides 1/2 the fuel required for the combustion process. Thus, 2 injections of fuel (2 rotations of crankshaft) are mixed with incoming air to produce the fuel charge for each combustion cycle. On models equipped with dual injectors in the throttle body, injectors are pulsed alternately.
Fuel System Operating Modes
Internal ECM calibration controls fuel delivery during starting, clear flood mode, deceleration and heavy acceleration.
Starting
During engine starts, ECM delivers one injector pulse for each distributor reference pulse received (synchronized mode). Injector pulse width is based upon coolant temperature and throttle position. ECM determines air/fuel ratio when throttle position is less than 80 percent open. Engine starting air/fuel ratio ranges from 1.5:1 at -33°F (-36°C) to 14.7:1 at 201°F (94°C). At lower coolant temperatures, injector pulse width is wider (richer air/fuel mixture ratio). When coolant temperature is high, injector pulse width becomes narrower (leaner air/fuel ratio).
Clear Flood
If engine is flooded, driver must depress accelerator pedal to Wide Open Throttle (WOT) position. At this position, ECM adjusts injector pulse width equal to an air/fuel ratio of 20:1. This air/fuel ratio is maintained as long as throttle remains in wide open position and engine speed is less than 600 RPM. If throttle position becomes less than 80 percent open and/or engine speed exceeds 600 RPM, ECM changes injector pulse width to that used during engine starting (based upon coolant temperature and manifold vacuum).
Heavy Acceleration
ECM provides fuel enrichment during heavy acceleration. Sudden opening of throttle valve causes rapid increase in MAP signal. Pulse width is directly related to MAP, throttle position and coolant temperature. Higher MAP and wider throttle angles give wider injector pulse width (richer mixture). During enrichment, injector pulses are not in proportion to distributor reference signals (non- synchronized). Any reduction in throttle angle cancels fuel enrichment.
Deceleration
During normal deceleration, fuel output is reduced. This reduction in available fuel serves to remove residual fuel from intake manifold. During sudden deceleration, when MAP, throttle position and engine speed are reduced to preset levels, fuel flow is cut off completely. This deceleration fuel cut-off overrides normal deceleration mode. During either deceleration mode, injector pulses are not in proportion to distributor reference signals.
Battery Voltage Correction
ECM compensates for low battery voltage by increasing injector pulse width and increasing idle RPM. ECM is able to perform these commands because of a built- in memory/learning function.
Fuel Cut-Off
When ignition is turned off, injectors are de-energized to prevent dieseling. Injectors are not energized if RPM reference pulses are not received by the ECM, even with ignition on. This prevents flooding before starting. Fuel cut-off also occurs at high engine RPM to prevent internal damage to engine. Some models may also cut off fuel injector signals during periods of sudden, closed throttle deceleration (when fuel is not needed).
Jan 26, 2009 at 2:12 PM
GARYHUFF
Thanks for the speedy reply. I have high voltage so there has to be a tach signal. if this alone provides Injector timing signal through the VCM then Injectors should fire if they are Hot and the vcm sinks them to ground. I assume I should probe that tack signal at the ECM but haynes does not show anything other than a tach test lead at the ignition coil. This is a 16151111 vcm
any help
Jan 26, 2009 at 6:29 PM
KHLOW2008
  • 41,814 POSTS
The tachometer receives its signal from the ignition coil. The ECM receives its signal from the distributor ICM. ( PURPLE/WHITE wire in diagram ) Injectors are grounded from signals from the distributor and you should test ECM terminal B5 for distributor pulse input.
https://www.2carpros.com/forum/automotive_pictures/192750_ECM92Astro01_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_ECM92Astro01a_1.jpg
Jan 29, 2009 at 6:34 AM
