I have a 92 Astro van with a 4.3 non Vortec that runs fine when the engine is cold but when the engine is warm it will idle fine and when you push the gas pedel to the floor quickly it will rev up ok. My problem is when I press the gas pedel slowly the engine will stall. I pulled the coil wire off the dist cap and my spark is yellow. Any advice will be greatly appreciated. I removed the EGR valve cleaned it and reinstalled it without the vacuum hose on it and it didnt make a difference,do you think it could be the throttle position sensor?
Jan 17, 2008 at 11:36 AM
