1990 Chevy Astro new battery keeps on getting drained from
1990 CHEVROLET ASTRO
16,700 MILES • 6 CYL • 4WD • AUTOMATIC
MY90ASTRO
It's not the battery. I replaced the new one already after a week. It's not the battery. The alternator is only 2 and a half years old. The battery cables are about 6 months old. The first time, it was my fault; I left the lights on. I then had the battery replaced. It was running good. I always watch the battery symbol gauge, and it wasn't going down; it stays in the middle. However, I do usually only go out at night, and I usually have the heater and radio on, but again, the battery gauge thing doesn't show a drain from that. Then, the next night, (it has been getting colder lately) when I start, it doesn't crank. (I did not leave anything on.) I just hear a click, and then after a few tries, no click at all. I buy a battery charger and charge it. After 30 percent charged, it starts up, and I properly remove the battery charger; I leave it in idle for a half an hour. The next night, I start it up, and it cranks poorly but doesn't start. After a few tries, it no longer cranks; it just clicks, and then just a click. I would think that after idling it for a half an hour, it would fully charge. Am I wrong to think that? And even if I do find out that it is still not fully charged, what caused it not to crank? Please help.
Dec 6, 2008 at 9:18 PM
Get the battery load tested if it cannot hold 9.6volts in 10secs its no good. It takes 12.6 volts to consider fully charged. Double check your connections even at the starter end.
Other possible areas could be the ignition switch, park and neutral switch and starter itself.
Dec 7, 2008 at 1:26 AM
