1990 Chevy Astro CREEPING BRAKES
1990 CHEVROLET ASTRO
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUDEBOY01
HI, I REPLACED SHOES ,PADS, WHEEL CYLINDERS,AND MASTER CYLINDER AND BLED THE BRAKES. AT A STOP THE BRAKE CREEPS TO THE FLOOR. AT A STOP I PUT THE VAN IN NEUTRAL TO AVOID ROLLING FORWARD. I HAVEN'T TAKEN IT TO THE DEALER YET TRYING TO AVOID THE BIG CHARGES.
Feb 17, 2008 at 8:36 AM
MERLIN2021
  • 17,250 POSTS
Bench bleed the master by getting brass plugs and screw them into the two ports, then pump the master until you cant move the piston any more. Attach the lines, Have an aide press and hold the pedal crack the lines and retighten, repeat this till all air is removed at the lines, Don't let the master run dry, bleed rear cylinders by opening the bleeders and wait until the fluid dripps out. Close bleeders. Make sure the rears are properly adjusted, then test the pedal hieght You still have air, or a leak...
Feb 17, 2008 at 9:39 AM
