1988 Chevy Astro charging
1988 CHEVROLET ASTRO
107,999 MILES • 6 CYL • 2WD • AUTOMATIC
STEVENJOEO6
new altenator,new battery and i cant seem to keep my battery charged.I will be happy to donate when you show me that you have helped me.sorry i've been suckered before
Oct 9, 2008 at 2:15 PM
JDL
  • 16,098 POSTS
Did you do any testing, before you replaced anything?
You can place voltmeter leads across battery posts, with everything turned off, take a reading. Start the vehicle, take a second reading across the battery posts, the second reading should be higher than the first, if the alternator is charging. You can also take a reading at the bat terminal on the alternator.
If you think there is an access drain, with everything turned off, you can check amp draw, around 30 ma,.030, should be max. You could also try a testlite between the battery post and cable, it shouldn't lit-up, but it's best to check the amp draw. You can check there are no interior lites left on, in the vehicle, glove box, overhead interior lite, under the hood, in the trunk. You can also pull fuses one at a time, when you pull the correct fuse, no more drain.
If you want to donate to the site fine, but, my info is free. You know what they say about free information.
Oct 10, 2008 at 10:45 AM
