What causes “Check Vehicle Stability Control System” to display?
My 2017 Camry was in an accident. Immediately after the accident, the dash display indicated, “Check Vehicle Stability Control System”. The car returned home (less than 5 miles) and still had that indication. It remained parked, and after some internet searching it seemed worth checking for an OBD-II code. I did try to do that, but by the time I had the code reader connected the “Check Vehicle Stability Control System” appeared to clear itself before I even had a chance to read the code. Is that surprising?
Could the code have cleared simply by cycling the ignition key on and off a few times?
I’m anticipating that someone will suggest that I accidentally cleared the code, but I’ve used my code reader enough times to find that explanation rather unlikely, but possible.
Could the code have been set because of hard brake application in attempt to avoid the accident?
May 5, 2019 at 12:44 PM
