Popping noise after every rev, then white smoke, engine shuts off and will not start?
2008 AUDI A4
190,000 MILES • 2.0L • TURBO • 2WD • MANUAL
UZZY0011
  • 4 POSTS
The engine light was already on before this happened. (Exhaust oxygen system) the car drive fine. Before this happened.
Basically, I’m driving everything is fine then a message pops up, (check oil turn engine off) I assumed it was low, so I topped it up, the light was still on. I then begin to drive and it’s making like a popping noise after every rev. Then white smoke comes out and the car turns off. It now won’t turn on. This happened in the space of 15 minutes. I don’t know what the problem could be?
Aug 15, 2022 at 1:57 PM
SQM
  • 6,383 POSTS
Before adding oil did you check to see if the oil was actually low?
Keep in mind that having too much oil can also cause internal engine damage due to high pressure.
Also did the engine to overheat.
Typically, white smoke out of the exhaust means a blown head gasket. Which will allow coolant to enter the engine and mix with oil.
So, if you check the oil and it is a milky white color then that is what happened.
Take a look at this guide:
Let me know of any questions.
Thank you.
Aug 15, 2022 at 4:01 PM
UZZY0011
  • 4 POSTS
Thanks for your reply! Yes, i checked it was low, but I topped it up with 5 liters. But before this, the car was in limp mode on the way to the shop to buy oil and filling it.
Aug 16, 2022 at 12:52 AM
UZZY0011
  • 4 POSTS
The codes from today.
Aug 16, 2022 at 10:49 AM
SQM
  • 6,383 POSTS
So what does the car do now. Does it crank and not start?
Also did the engine overheat?
Aug 17, 2022 at 5:45 PM
UZZY0011
  • 4 POSTS
No, it doesn’t start, not even turn over. Currently in a garage but they still haven't looked at it. I don’t think the engine overheated. I’m just not sure anymore.
Aug 18, 2022 at 2:05 PM
SQM
  • 6,383 POSTS
The vehicle goes into limp mode to protect the primary components like the engine/transmission. Many times the ECM will need to be reset before it will let you start the engine. Disconnecting the battery can help reset it.
Let me know what the shop says.
Aug 19, 2022 at 11:40 PM
