I have the vehicle listed above with a brake system problem. It keeps failing and makes a very loud beeping noise. When that happens, the brake goes to the floor and there is a check brake warning signal on the dashboard. The issue goes away when you park the car for about 30 minutes and comes back on again after driving for another 15-30 minutes.
I have checked online and this is an ongoing issue a lot of people are going through. could it be the hydraulic power unit assembly/ hydraulic pump?
One more thing, my car has a minor leaking oil issue also. Does that have anything to do with the brake issue I am having? I have checked the brake fluid and everything looks good.
Your help will be appreciated.
May 8, 2020 at 4:02 AM
