Check hybrid brake light with noise when brake pedal goes to the floor
2013 HYUNDAI SONATA HYBRID
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
ISMAEL NIADA
I have the vehicle listed above with a brake system problem. It keeps failing and makes a very loud beeping noise. When that happens, the brake goes to the floor and there is a check brake warning signal on the dashboard. The issue goes away when you park the car for about 30 minutes and comes back on again after driving for another 15-30 minutes.
I have checked online and this is an ongoing issue a lot of people are going through. could it be the hydraulic power unit assembly/ hydraulic pump?
One more thing, my car has a minor leaking oil issue also. Does that have anything to do with the brake issue I am having? I have checked the brake fluid and everything looks good.
Your help will be appreciated.
May 8, 2020 at 4:02 AM
Good morning,
Are there any codes set in the system for the brakes? Yes, it could be but needs to be verified.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
When it resets, do the brakes work okay with a good pedal?
I need the code that is set so I can narrow the area of the failure for you.
May 8, 2020 at 4:17 AM
