Check gas cap light and Check Engine Light on?
2002 FORD ESCAPE
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAMIE SIMS
Both lights are on, and I have checked gas cap making sure it is secured when driving vehicle hesitates or shuts off at stops and when moving it jerks and bucks around 50-60 MPH but will smooth out some over 60.
Mar 5, 2023 at 10:26 PM
The first thing we need to do is run the codes to see what comes up to see if the problems are related. This guide can help:
Next, I would remove the gas cap to see if the sealing o ring is in good shape and for the stalling problem I would do a tune up while replacing the ignition coils. This is a common problem on these engines.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Service the throttle body as well.
Check out this video of the job being done. Make sure you do the rear cylinders.
https://youtu.be/3ZpAQRO0IJg
Please go over these guides and report back.
Mar 6, 2023 at 11:05 AM
