Check engine light on
2004 SUZUKI VITARA
80,000 MILES • 6 CYL • 2WD
NORA ALLEN
Check engine light on showing misfire on six. Replaced all plugs check engine light still on.
Jun 26, 2018 at 5:43 AM
Good morning.
Besides plugs other possibilities are:
1. Low compression.
2. Vacuum leak at the intake manifold.
3. Coil or wiring at the coil.
4. Clogged injector. do not use additives in the fuel as they have no effect.
5. Quad driver in the PCM not commanding the injector to fire.
Jun 26, 2018 at 5:59 AM
