Check engine light with codes p2105 u0300
2008 FORD E-SERIES VAN
123,567 MILES • 5.4L • V8 • RWD • AUTOMATIC
WENDY MORSE-LEIGHTON
Engine stops running at idle and driving. I replaced throttle body and PCM checked wiring to throttle body and accelerator pedal position sensor found no problems.
Nov 7, 2016 at 4:14 PM
AL514
  • 5,465 POSTS
Your U0300 is "Internal Control Module software incompatibility".
Nov 7, 2016 at 4:41 PM
It is an e350.
Nov 8, 2016 at 3:30 PM
Does the PCM need to be reprogram by the dealer?
Nov 8, 2016 at 3:38 PM
AL514
  • 5,465 POSTS
it may need to be, but lets put this on hold until tomorrow. I will dig into this more and give you my best idea of where to go next. I do not want to guess, I would much rather give you the best path to take next so you are not wasting money and time if that is okay with you. deal? we will figure this out.
Nov 8, 2016 at 4:30 PM
AL514
  • 5,465 POSTS
ok so what I found is that the U0300 code is software level related and will interfere with the electronic throttle by wire system that you have, which is why you are getting the P2105 throttlebody code. considering you have replaced the ECM I think is safe to say yes the ECM needs to reprogrammed with the correct software level so there is proper communication to the throttlebody motor from the pedal position sensor and the ECM.
Nov 10, 2016 at 10:30 PM
